May 24, 201114 yr Hi guys hope you can point me in right direction, tried to start my wacker tonight and nothing ! been stood in garage for a couple of years checked oil, new petrol, will start when squirt fuel down plug, into carb so suspect blocked jet ? by the way checked fuel cock and fuel there removed bowl as well ,cannot go further at mo don't have socket to get carb off. Any advise appreciated Phil
May 24, 201114 yr Hi guys hope you can point me in right direction, tried to start my wacker tonight and nothing ! been stood in garage for a couple of years checked oil, new petrol, will start when squirt fuel down plug, into carb so suspect blocked jet ? by the way checked fuel cock and fuel there removed bowl as well ,cannot go further at mo don't have socket to get carb off. Any advise appreciated Phil Have you put fresh fuel in? If not i'd drain the old petrol out and get some new stuff in. A bit of easy start into the inlet will probably help too. GL.
May 24, 201114 yr Author Have you put fresh fuel in? If not i'd drain the old petrol out and get some new stuff in. A bit of easy start into the inlet will probably help too. GL. Hi thanks for your reply ,yes put fresh fuel in and it starts when I put a drop of fuel down plug hole or into carb so dont think it is a ignition prob,only other thing I did was top up oil ,poss too much so drained a bit off just in case this was the prob ?
May 24, 201114 yr Moderator Think of it this way Phil The head is the whacker plate the wall is the bent fork
May 24, 201114 yr Author Think of it this way Phil The head is the whacker plate the wall is the bent fork God I,m slow ,must be cos on Night,s well thats my excuse ,no it just another of the 50000.50 projects on with, in between the rain,wind,and "work"
May 27, 201114 yr Author God I,m slow ,must be cos on Night,s well thats my excuse ,no it just another of the 50000.50 projects on with, in between the rain,wind,and "work" Update wacker/honda now running fine.
