rob.patton Posted May 20, 2011 Posted May 20, 2011 what bigger carbs fit a dt 125 r "2001" i was thinking kmx kx ktm dt 175 yz rm ?????
Moderator Cynic Posted May 20, 2011 Moderator Posted May 20, 2011 Why, its already huge and a flatside, same size as the ones on my tdr easily good for 30hp+
rob.patton Posted May 24, 2011 Author Posted May 24, 2011 its only a 28mm carb, a rs 125 has a 34mm and a ktm 125 has a 38mm carb it would make a big difference but depends on if it will fit the inlet
rob.patton Posted May 29, 2011 Author Posted May 29, 2011 Why, its already huge and a flatside, same size as the ones on my tdr easily good for 30hp+ 30hp+ hummmmm maybe 20-22 hp
