DTR 125 Head Gasket Issues
RichtheMac
This post is 4929 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Does anyone have any advice when changing the head gasket on my DTR 125? I have performed this operation twice now and ,surprise surprise, it has gone again and is blowing water (shud be coolant-I know..!) back down the barrel and out the exhaust. :( I have used gasket sealant on both occasions. Should I get the head skimmed (the barrel has been rebored and new piston fitted) or am I doing something wrong when I am refitting the head. The gasket has been fitted the right way up and at first the radiator was not losing any water..Also -can I skim the heead and top of the barrel with a bit ov wet and dry??
:unsure:
Link to comment
Share on other sites
I have used a cheap one once and sure enough it failed. I use proper ones now and run a thin film of silicone manifold sealant around where the bore is only about 7mm wide not the whole gasket (you have to get it off again sometime) do this both top and bottom.
Your head may be warped though I cant comment on that but skimming should be done proffessionally in my opinion. At a guess place the head on a piece of glass and ensure it doesn't rock in any way.
Link to comment
Are you using a torque wrench to tighten the nuts in a criss cross pattern and to the proper torque which should be 22nm or 16lb ft.I usually start of tightening to a lower setting in a criss cross pattern i.e 10nm or 7 lb ft before tightening to the final figure and checking again after the engine has got up to temperature and cooled down. As mentioned get the head checked to make sure it isn't warped and make sure the faces haven't got any old gasket left on them before putiing on the new gasket. You shouldn't need any sealant on the gasket providing the head isn't warped.
Link to comment
Good advice Tony, some nuts can be torqued but the DTR gives too little clearance for sockets on some cyl head nuts, so a little guesswork with a ring spanner has to be applied.
DTRs are renowned for blowing gaskets and so I will say again a thin line of silicone around the bore circumference (just 7mm wide) is of benefit and it cleans off quite easily,
Link to comment
  • Recently Browsing
