Posted May 13, 201114 yr Can anyone help with suspension settings for a 2005 R6, I am 15 stone and the bike is still at the standard settings. The rear end looks a little low, unless this is normal just had the fork oil changed Thanks Ian
May 13, 201114 yr Have a read of this: http://www.moto-racing.co.uk/Guides/motorcycleSuspensionSetup.htm appears informative. Maybe someone else can be more precise? If you live up north you can always check out alpha suspension for a personalised setup Graham
May 13, 201114 yr Well ian, it depends on what your intentions are , ie, Track days or just back road riding, Ther"s a few of my mates have sports bikes, after every ride-out, say 200mls , They are battered with stiff suspension set up. First thing i did wen aquiring my Zrx , was to back off the rear spring adjusters, and rebound setting, for a comfy ride, ,
May 14, 201114 yr Author Have a read of this: http://www.moto-racing.co.uk/Guides/motorcycleSuspensionSetup.htm appears informative. Maybe someone else can be more precise? If you live up north you can always check out alpha suspension for a personalised setup Graham Thanks graham, I'll have a look at the set up and use that link Ian
