1980 Yamaha XS400 Special Only firing on one cylinder
Greenerict
This post is 4925 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Have you checked to see if down pipes are getting warm when you run the bike?If one is warm and the other is cold then check that for a spark at the plugs
Link to comment
Share on other sites
They both warmed up, and there is a spark on both sides.
The O-ring and washer came out after the mixture screws. Everything looks fine. I just need to find some plugs now.
And I'll check for leaks if this doesn't work out, I appreciate the help
Link to comment
I'm sure you don't really need the plugs, they are there to stop peeps messing with the settings
Link to comment
  • Recently Browsing
