1980 Yamaha XS400 Special Only firing on one cylinder
Have you checked to see if down pipes are getting warm when you run the bike?If one is warm and the other is cold then check that for a spark at the plugs
They both warmed up, and there is a spark on both sides.
The O-ring and washer came out after the mixture screws. Everything looks fine. I just need to find some plugs now.
And I'll check for leaks if this doesn't work out, I appreciate the help
I'm sure you don't really need the plugs, they are there to stop peeps messing with the settings
