May 13, 201114 yr Hi does anybody know where I can buy a new ignition switch for my 2000 Yamaha dragstar xvs 650 from? I've tried eBay and other sites but none of them are the right ones, I need one asap really
May 13, 201114 yr Author tried wemoto? bitzforbikes? yamaha? yes i did thanks but even they didnt have one to fit, do you know if there are any that i could use instead of the actual part?? thanks alot
May 13, 201114 yr Depends what part of the switch assembly is broken. You mean the ignition cylinder where you put the key, or the starter switch? What part is broken? Button itself, the switch behind it, a contact, a retaining tab? More info, please.
May 13, 201114 yr Moderator bike bandit speed sport (yamaha topdog) failing all of the aboive, get the part number for cmsnl and google it. see what comes up
May 16, 201114 yr In what way is it broken? Can you get the key in? Does it turn, is there no initialisation? Full info needed.
