Posted May 13, 201114 yr Does anybody know of an aftermarket digital speedo that will fit in the xvs650 housing please ? It's 10cm across so pretty big compared to most of the aftermarket one's i have seen Cheers all Al
May 13, 201114 yr Author I can find plenty with a diameter of approx 6 1/2 cm but nothing big enough to fit the dragstar housing
May 15, 201114 yr This idea has also been on my mind over the last few days, just thought it'd be a bit of a different and nice touch. The one I saw that looked the nicest was the Acewell 2856AB, (i may be dreamin as it's a little expensive but hey) was about 70mm in diameter. Wouldn't it be possible to make some sort of bracket that decreases the hole in the original clock holder so that it could sit in it?
May 15, 201114 yr Author I have been toying with the same idea LivetoRide,maybe stainless steel disc with the correct diameter hole cut in the middle then epoxy resin it in
May 20, 201114 yr I have been toying with the same idea LivetoRide,maybe stainless steel disc with the correct diameter hole cut in the middle then epoxy resin it in i d like to fit one too you can buy a guage that has tach an shift an some other things built in but i dont have a clue how to wire it, shift light only works if you have a tacho fitted as standard apperantlty
May 23, 201114 yr i saw the dash here http://cgi.ebay.co.uk/Koso-RX2n-LCD-Dash-Tacho-Speedo-Large-Shift-Light-/270745520559?pt=UK_Motorcycle_Parts&hash=item3f09b0c9af google them they make different types also google vapour an acewell dashs
May 24, 201114 yr Wow... Those Acewell things actually look rather cool!! I'd have to completely overhaul my bike to suit the look, but I was planning on doing that one day anyway...
