Hey all
First time on the forum and could not located a similar thread so started this one
Had my bike under m/c cover but out in the elements for about 1 1/2 years, replaced the motor and reconnected all the plugs.
Removed an after market heated grip setup and cut and insulated the wiring that was used for these grips.
turned the key and the only thing that works is the clock....press starter, horn nothing (fully charged battery checked with meter)
no neutral or oil light
I did spray some wd40 into the kickstand switch as it was really sluggish but is now free moving. (is wd40 conductive?)
I still have the front fairing removed so the headlight and front indicators are disconnected.
some advice would give me a starting "points"....;]
Hey all
Welcome to the Yamaha Owners forum :welcome:I just guess you have not got everything connected don't forget all circuits need to wired in .... my Divi did 3 years in a shed (and without the removal of the fairing) fired up no problem .. but perhaps check the fuses and insure that the battery 'really' is good enough .. perhaps just run a car battery in series but without more info this will be difficult to solve
