November 30, 200420 yr hi any one tried taking the exup valve out of the exhaust?? any problems with this?? thanks..
December 1, 200420 yr If you mean taking the exup exhaust off and fitting an aftermarket set of downpipes, don't bother, just have a read through the forum, you will see why;) if you mean just taking the valve out, you will have the same performance issues, assuming you get it out, but i bet you will have at least one of the bolts holding the plate on, seized. why are you wanting to take it out?
December 1, 200420 yr Moderator pointless taking it out unless you are rejetting and putting a full race system on then spending lots on dyno time :shock:
