MOTORCYCLE REPAIR COURSE
Follow the link
http://www.dansmc.com/MC_repaircourse.htm :unsure:B)
GETTING STARTED
Just Do It! Getting started for the very first time.
Shop Safety Avoiding the Pain.
Helmets Skidlids, and why you need one.
2 & 4 Stroke Engine Basics How an Engine Works.
Motorcycle Glossary Some Very Basic Definitions for the Beginner.
Shop Manuals The Spec's for your Engine.
The Ultimate Shop Manual The Spec's for the Human Machine.
Online Manuals Free Shop and Parts Manuals Online.
A Career in Motorcycle Repair A different view, That's for sure.
Quick Troubleshooting Do These Things first!
Trouble Shooting a Used Bike Should I buy that thing or not?
Trouble Shooting a Bike that Will Not Start. Making that old dog run.
Definitions What does a Tune-Up or Top-End Job, consist of?
Troubleshooting Plan... Planning how to fix the problem.
Basic Tools For the beginner...Tools 101!
Advanced Tools The next step up, or what do I want for next Christmas.
Impact Driver... Your first Special Tool.
Good Shop Practice... Go fast without really trying.
HomeWork Every School has homework... Here is yours!
HomeWork 2... Don't worry, this will be fun!
GENERAL STUFF
Engine Start Up Start'n her up.
New Engine Break-In Breaking it in without breaking it up.
Mysterious Two Stroke Seizure Getting stuck without trying!
HopUp Getting you more power.
Remove Your Seat "Fix My Bike ? ? ? I can't even get the seat off." Here's Tips on how to do it.
Chemicals Some slippery stuff, that.
Cleaning Parts You can really clean up with this one.
Air Tools How to use Air Tools Right.
Hot & Cold How to make a part's Temperature work for you.
Worrying Removing that stuck, rusted, part.
Piddling Making it work when you don't know how.
Winter Storage How to Store Your Bike Right.
Fastener Theory Trying to Hold it together.
Torquing Bolts Torque it down. Wow, that sounds dirty, doesn't it!
Fixing Bad Threads. Torqued it down too much, didn't you.
Stripped Bolts and Screws How to fix stripped out bolts and screws.
Sand Blasting Blowing Chunks, so to speak!
Chinese Bikes The Chinese Revolution.
Locating Parts Getting The Right Part.
LUBRICATION
2 Stroke Oil Keep Your Ring-Ding Ringing.
4 Stroke Oil Keep that Engine Oiled.
Changing your Oil, Page 1 Changing your Oil and Filter.
Changing your Oil, Page 2 Getting it all on the Level.
Two Stroke "Auto-Lube" Oil Pumps Lubing 'er up without fouling 'er out.
Two Stroke "Auto-Lube" Systems Different Strokes for Different Folks!
Four Stroke Lubrication Lubing her up!
Four Stroke Oil Flow Systems How do they lube that?
Gaskets Keep the Oil Where it Belongs.
Grease Keeping the goo compatible.
FUEL
Gasoline About the Fuel You Burn.
Gas Tanks Keeping the Go Juice from leaking away.
Carburetor Theory and Tuning Changing those jets.
Carburetors Servicing your Caburetor.
Balancing Carburetors Matching the Throttles.
Exploded Carburetor Veiws Lot and Lots of Carburetors!
Pumper Carbs Blow that fuel in!
Two Stroke Power Valves Power from the Valves.
Reed Valves One way Flappers.
Air Cleaners Clearing the air.
ELECTRICAL
Ignition Timing Ignition Theory.
Magneto Timing Timing a Flywheel Magneto.
Electronic Ignition A Pointless Discussion!
Timing a Battery/Coil Ignition Is there a Point to this Discussion?
Electrical Testing Information that may prove to be Shocking!
Soldering The Joining of the Wires.
Batteries Servicing Your Battery.
Spark Plugs How to read a Spark Plug.
29 Spark Plug Images... Cold to Hot. Be Patient, it takes awhile to load.
Electric Starters Making her spin.
Exploded Starters Exploded Starter Views.
Generator/Starter/Dynamo Another way to spin it.
Virago Starter Problem A fix, perhaps, to an old problem.
ENGINE
Engine Compression Testing Finding the Pressure.
Four Stroke Compression Releases Venting the Pressure.
Two Stroke Compression Releases Venting that Pressure Two!
Four Stroke Leak Down Test leaking the Pressure.
Two Stroke Crankcase Vacuum/Pressure Testing This could really suck.
Four Stroke Exhaust Pipes Keeping the sound down.
Two Stroke Exhaust Pipes Expanding your chambers.
Valve Adjustment Keep those Clearances open.
Valves Servicing the Valves and Seats.
Pistons & Cylinders & Rings Work those Jugs Over.
Cylinder Hones Putting the Cross Hatch on.
Chinese Ring Instillation Which Rings are Which!
Gear Boxes How to slide those gears into position.
Gear Shifters Something Shifty Going On!
Exploded Gear Shifters More Shifty Dealings.
Clutches Slip in a new gear grabber!
Exploded Clutches Exploded Clutch Views.
Automatic Clutches Clutch lever? I don't need no clutch lever!
Exploded Automatic Clutch Views More Views, Automatically.
Counter Balancers Cooling the bad vibes.
KickStarters Kicking is an old habit!
Exploded Kickstarter Views Lots of old kicking habits.
Water Cooling How to keep your cool.
Unsticking a Stuck Engine Getting it unstuck.
Engine Plain Bearings Plainly some things are going around.
Roller Bearings Getting things rolling.
Valve/Cam Timing Getting the timing right.
Valve/Cam Drives How to drive those Cams.
Adjusting the Cam Chain Setting the Tension.
Cam Chain Veiws Different ways to set the Tension.
Splitting the CrankCases Split 'em up right.
FRAME
Bowden Control Cables Controling your cables.
Hydralic Brakes & Clutch Making Hydraulics Work.
Drum Brakes Make your Drum Brakes Brake.
Front Forks Replace those Leaking Seals.
Exploded Forks Exploded Front Fork Views.
Align the Front Forks Handlebar to Tire Alignment.
Front Wheel Removal Pull your fronts.
Rear Wheel Removal Pull your rears.
Changing Tires Fix a Flat Tire.
Spoke Wheels Truing your rims.
Rear Chains & Sprockets The Transfer of Power.
Wheel Bearings keeping your rims rolling.
Steering Bearings keep your Handlebars Turning.
Twist Grip Throttles Turning the power on and off.
SPECIFICATIONS
Specifications Motorcycle Specifications.
Motorcycle Software Programs for your Bike.
