May 9, 201115 yr Hi I replaced Headlight's bulb with a Xenon bulb which gave a very bright beam two days ago, but last night when I was riding at night it blew off..both filaments burned out..is it possible for some electrical problem the leads can bring a higher voltage to the bulb?....thank you people..
May 10, 201115 yr if anything it will be a short in the electrics, are the fuses ok? and what volt fuses have you got? also did you get the right power bulbs?
May 10, 201115 yr Author if anything it will be a short in the electrics, are the fuses ok? and what volt fuses have you got? also did you get the right power bulbs? The bulb was a 12V/60-55W Xenon one..Yes fuses are ok, I should check all once again..
May 10, 201115 yr The bulb was a 12V/60-55W Xenon one..Yes fuses are ok, I should check all once again.. thats a little strainge......what size/voltage fuse have you got? if memory serves me right it should be a 15A for the lighting circuit so it just blows the Xenon bulbs and not standard ones?
May 10, 201115 yr Author thats a little strainge......what size/voltage fuse have you got? if memory serves me right it should be a 15A for the lighting circuit so it just blows the Xenon bulbs and not standard ones? Oh seems thats the case, Xenon bulbs require more amperage? I put a Halogen one with same wattage..it still works (since yesterday )Will check fuses..but if the Xenon drew more current fuse should blow out right, but fuse seems to be ok as the second bulb still lights up...
