Overloads possible in XV 125's headlight wire leads?
Hi I replaced Headlight's bulb with a Xenon bulb which gave a very bright beam two days ago, but last night when I was riding at night it blew off..both filaments burned out..is it possible for some electrical problem the leads can bring a higher voltage to the bulb?....thank you people..
if anything it will be a short in the electrics, are the fuses ok? and what volt fuses have you got?
also did you get the right power bulbs?
The bulb was a 12V/60-55W Xenon one..Yes fuses are ok, I should check all once again.. :unsure:
thats a little strainge......what size/voltage fuse have you got? if memory serves me right it should be a 15A for the lighting circuit
so it just blows the Xenon bulbs and not standard ones?
Oh seems thats the case, Xenon bulbs require more amperage? I put a Halogen one with same wattage..it still works (since yesterday :lol: )Will check fuses..but if the Xenon drew more current fuse should blow out right, but fuse seems to be ok as the second bulb still lights up... :unsure:
