Posted May 7, 201113 yr Hello, My yamaha chappy's throttle was a bit sticky and when riding would stick on before slowly releasing a bit and returning to normal. I opened the cable splitter box and WD40'd it, the splitter moved backwards and forwards nicely. I then opened the carb top where one of the cables goes and the slide is clean and seems ok. I also opened where the other cable goes and it's attached to what looks like a throttle body of a car (dont know what the actual part is, when your messing around with a car and you rev the engine by moving the wheel, looks like that). After doing all this, now when I bump start it, the throttle is on full at idle and I cant shift back to neutral (as the revs are too high). Any ideas what could be up? I've ordered a new throttle cable, but it's gonna be about a month before i get it. So it would help for me to get thing going.
