Posted May 6, 201114 yr Hi All, was wondering if anybody knows the correct torque setting for tightening the 4 clutch bolts on a virago 125? any info would be helpful. Thanks, Les
May 6, 201114 yr Hi All, was wondering if anybody knows the correct torque setting for tightening the 4 clutch bolts on a virago 125? any info would be helpful. Thanks, Les if you mean the 4 that hold the springs in, then I can only tell you that its 8Nm on the dragstar 125, which is pretty much the same engine. Anyone confirm that?
May 6, 201114 yr Author if you mean the 4 that hold the springs in, then I can only tell you that its 8Nm on the dragstar 125, which is pretty much the same engine. Anyone confirm that?
May 6, 201114 yr Author if you mean the 4 that hold the springs in, then I can only tell you that its 8Nm on the dragstar 125, which is pretty much the same engine. Anyone confirm that? Hi, Those are the 4 bolts I'm enquiring about.
