Posted May 6, 201114 yr hey all! i just took apart my mikuni bs34 carbs for a cleaning and a tune up. One of the several things i planned to do was to replace the worn and damaged jet needle. The throttle slide is removed with the rubber diaphragm still in tact, but i cannot figure out how to remove the current needle from the slide body... your thoughts? thanks in advance! Ry
May 6, 201114 yr Moderator usually theres a tiny circlip deep inside the body. Its been a while since i did my carbs and the laetr carbs are less easy to work on!
