xs 400 carb throttle slide and jet needle
hey all!
i just took apart my mikuni bs34 carbs for a cleaning and a tune up. One of the several things i planned to do was to replace the worn and damaged jet needle. The throttle slide is removed with the rubber diaphragm still in tact, but i cannot figure out how to remove the current needle from the slide body...
your thoughts?
thanks in advance!
Ry
usually theres a tiny circlip deep inside the body. Its been a while since i did my carbs and the laetr carbs are less easy to work on!
