Need help with neutral light
Hey Guys,
Have been trying to diagnose my lack of idiot light on my dash.
I'm kind of stumped as to what to try next.
So far I've
- traced the neutral wire back to the connectors (sky blue) to test with a test light. This didn't work
- replaced the neutral switch.. Still didn't work.
Have looked at the wiring diagram and can't think of anything else that may be causing it not to work?
any ideas
Cheers
Blown bulb ? Also try disconnecting the wire that goes on the neutral switch and connect it to earth. If the light comes on it must be something to do with the neutral switch .If it doesn't you have a bulb or wiring problem.
did you earth out the light blue wire near the neutral switch?
if the lamp didn't light its either a live supply problem or, as said, the bulb has gone and needs replacing!
Cheers guys,
Tested the neutral switch and that was ok. Worked out to be an old wiring issue.
Thanks for the help
