FujiwaraTofuShop Posted May 4, 2011 Posted May 4, 2011 Hi guys just bought a Yamaha Virgao 125, the milieage is 1300, reg 99. The bike is in the superb condition i started it in my garage probably more than ten times on numerous occassion, works perfect. But the other day it just stoppped starting. it ticks over makes the noise but the bike would not start. The lights and other tings come on. Even tried using a bike battery charger and filled up the tank too. I don't have a clue about bikes. Plus I was looking for a kick-start but the Virago doesn't have one All help would be appreciated, plus someone recommended that i check the spark plugs to see if i've flooded the engine, or if they're dirty. Ali - Birmingham
barkwindjammer Posted May 4, 2011 Posted May 4, 2011 Whats all this shouting ?, we'll have no trouble here !
FujiwaraTofuShop Posted May 4, 2011 Author Posted May 4, 2011 Whats all this shouting ?, we'll have no trouble here ! I'm sorry but I've lost you.
Moderator Airhead Posted May 4, 2011 Moderator Posted May 4, 2011 Greetings FTS is there a prime [PRI] position on the fuel tap ? If so...try that
neversaydie Posted May 5, 2011 Posted May 5, 2011 Hi guys just bought a Yamaha Virgao 125, the milieage is 1300, reg 99. The bike is in the superb condition i started it in my garage probably more than ten times on numerous occassion, works perfect. But the other day it just stoppped starting. it ticks over makes the noise but the bike would not start. The lights and other tings come on. Even tried using a bike battery charger and filled up the tank too. I don't have a clue about bikes. Plus I was looking for a kick-start but the Virago doesn't have one All help would be appreciated, plus someone recommended that i check the spark plugs to see if i've flooded the engine, or if they're dirty. Ali - Birmingham Start by having a real good read of your owners manual, it explains the choke/petrol tap/warning lights etc, too make sure that you understand how the bits and bobs work Welocome and good luck
