sr250 help
I'm having problems with my '81 sr250, I had had it running great and then I had problems with it starting, I can push start it OK after a few tries, and I do not have a kickstarter installed, the last time I had it running from a kick start it was running lean, and I figure this would be due to a problem with the mixture screw which I have yet to mess with. When I try to start the bik it wil turn over but will not fire, I was wondering if this would all be due to a problem with the mixture screw or wat else it could be any help would be great!!!
sounds like it needs a tune up! and maybe a new battery
I set the cam chain and the pistons to the right gaps and also checked the timing and it is right where it needs to be I have had the baterry on the carger and it is pretty new and I have cleaned the carbs, so its been pretty tuned up new spark plug correctly gapped and its getting a good spark and I have had it running it just wont fire, I've heard the wrong air mixture to cause this, but I wanted to get any feedback possible
