Identification help please fellas
Guys i wonder if you could help me ID which model RD these forks are off and also the master cylinder..check these pics out and see if you know as i cant order parts unless i know the right model... :)
The forks look like late model i.e 1980 RD200DX . Can you measure the diameter of the stanchions as pretty sure they were smaller diameter then the RD250 and RD400. Tony
upper forks are 30.2 mm and lower 39.25.. :D
If you prise out the rubber cap from the very top of the fork where it goes into the top yolk and find a large hexagon bolt I'm sure these are 1979/1980 RD125DX/RD200DX forks. Tony
thanks Tony i will take a peek.. :)
ok theres no hex nut Tony only what looks like a core plug.. see attached [ic
