April 27, 201114 yr any one have a dt175e 1978 enduro do you know where to mount the voltage regulator the rectifier goes under the gas tank but i have not figured out where to mount the voltage regulator so can anyone help me out? the yellow wire is the regulator connector i just cant locate where to attach the reculator
April 28, 201114 yr Moderator any one have a dt175e 1978 enduro do you know where to mount the voltage regulator the rectifier goes under the gas tank but i have not figured out where to mount the voltage regulator so can anyone help me out? the yellow wire is the regulator connector i just cant locate where to attach the reculator 175e, thats the same as Oldgitonabike's, on a bracket on the airbox i believe. The later F's (like mine)had it mounted direct to the frame above the rear brake light switch.
April 28, 201114 yr Moderator Yes it's at the bottom of the battery compartment, near the drive chain
