any one have a dt175e 1978 enduro
do you know where to mount the voltage regulator
the rectifier goes under the gas tank
but i have not figured out where to mount the voltage regulator
so can anyone help me out?
the yellow wire is the regulator connector
i just cant locate where to attach the reculator
175e, thats the same as Oldgitonabike's, on a bracket on the airbox i believe. The later F's (like mine)had it mounted direct to the frame above the rear brake light switch.
i ended up mounting it straight to the motor
