April 26, 201114 yr hey all, iv got a problem with my dragstar. im getting no spark to both plugs, the engine cranks and fuel goes into the cylinders but im getting no spark. it came about when i was riding home, the chain fell off and the bike cut out (does this on the regular when i pull up on the drive and let the gas right off, revs dip and bike cuts out, so i assumed nothing, it was normal for me) i pushed it up the drive and could not get it going, check both plugs, no spark. tried new plugs, still no spark. i dont believe both ignition coils could die at the same time. thanks for your help.
April 26, 201114 yr Chain fell off????!!!! Bike sounds like it's in a real state of disrepair. I suggest taking the bike to a mechanic and getting a top-to-tail service!!! Ask him to let you watch and learn everything you can about keeping it in shape.
April 26, 201114 yr hey all, iv got a problem with my dragstar. im getting no spark to both plugs, the engine cranks and fuel goes into the cylinders but im getting no spark. it came about when i was riding home, the chain fell off and the bike cut out (does this on the regular when i pull up on the drive and let the gas right off, revs dip and bike cuts out, so i assumed nothing, it was normal for me) i pushed it up the drive and could not get it going, check both plugs, no spark. tried new plugs, still no spark. i dont believe both ignition coils could die at the same time. thanks for your help. You've been lucky, a chain off at speed can cause a serious accident. Did it just "come off" or did it snap? Either way, points to lack of proper care through too slack or rusty and dry not sure that I understand why the bike only cuts out on the drive,, do the revs dip at junctions/traffic lights etc or is it just on the drive? Check to see if the chain has damaged the side stand switch when it came off
April 27, 201114 yr Author the bikes a daily driver and has seen all weather apart hail and without it everything becomes a struggle for me in travelling, im looking to restore this one, i admit its not in top form but i have no resources to keep it in top nick. I do the bare basics for it to keep it going thats about it.
April 27, 201114 yr the bikes a daily driver and has seen all weather apart hail and without it everything becomes a struggle for me in travelling, im looking to restore this one, i admit its not in top form but i have no resources to keep it in top nick. I do the bare basics for it to keep it going thats about it. Do you have an owners manual?
April 28, 201114 yr Author got owners and service manual, had my friend look at it. could be the relay or a corroded wire.
May 9, 201114 yr Had same problem on my 125 after being stolen recovered. Even with a new battery I was getting nothing but it was just one of the 30 blade fuses in the box under the l/h/s of the seat. Easy fix and was very relieved!
