April 24, 201114 yr Recently laid down my 1992 Seca II. The end of the clutch handel and the rear footrest broke off. I removed the gear shift to get the bearings out of the footrest, and then reattatched it without the new rest (bikes still being repaired). I also removed the clutch handel and then reattatched it. Originally it made a clicking noise as this was being done and now it has ceased. The bike starts up just fine, everything seems to be in order, the engine murmers when i press the clutch down, and the gears shift fully when the bikes off. The only problem is every time i go from neutral to first while its on the bike dies. This is my only form of transportation for the next month and i feel like pulling my hair out. Any Help?
April 24, 201114 yr Moderator Greetings Mike, not being funny but I find your post difficult to understand, save for the fact you fell of! Are you saying the engine dies when you go from neutral to first gear?
April 25, 201114 yr Moderator ..........Are you saying the engine dies when you go from neutral to first gear? Yes. Without even releasing the clutch This is often a sign of sidestand switch disconnection or failure.
