I just bought a 1983 virago xv500 and there is a wire that goes to the clutch lever on the handle bars that is broken off. What is the purpose/function of this electrical connection? Its a single wire that goes into a hole right behind the clutch lever. The bike runs fine and I dont see any funtion that this could be impeding.
I'm guessing here, but I can only think that its the clutch switch wire, connects with the sidestand to prevent starting with the sidestand down and clutch engaged.
Should operate like this:
Sidestand down/bike in gear/clutch engaged - bike wont start
Sidestand down/bike in neutral/clutch engaged - bike should start
Sidestand down/bike in gear/clutch disengaged - bike should start
Sidestand up/bike in neutral/clutch engaged - bike should start
Sidestand up/bike in gear/clutch disengaged - bike should start
Check your sidestand for a switch presence
