April 22, 201114 yr Guys i need some advice please.. I am busy goign through the wiring on the RS125DX as it has been butchered in a few places.. it became apparent that every bulb i checked was fried so i replaced a couple and sure enough they worked without th eengine running.. now a strted the engine and within seconds 2 of the 3 bulbs popped and the 3rd one was very bright indeed which leads me to think theres far too much voltage reaching them... I dont know much about that side of electrics so can anyone help me and give me an idea as to why this is happening.. dodgy rectifyer or regulator?.. the rectifyer looks fairly new however the wiring too it is non standard.. any ideas guys
April 22, 201114 yr Moderator Yeah regulator trouble, visually inspect it and the connections to it, if its a one wire affair like on my DT175 they seem pretty reliable. I dont know the bike, how it's mounted or have a wiring diagram so can be much more help. I just posted something in the thread about 125 lights, same subject.
April 22, 201114 yr Author Yeah regulator trouble, visually inspect it and the connections to it, if its a one wire affair like on my DT175 they seem pretty reliable. I dont know the bike, how it's mounted or have a wiring diagram so can be much more help. I just posted something in the thread about 125 lights, same subject. ah therein lies a problem... nowhere in the manual does it mention a regulator only a rectifier...that is a 2 pronged doohickey screwed to the frame below the tank... cant find anything else that it could be...
April 22, 201114 yr Author ah therein lies a problem... nowhere in the manual does it mention a regulator only a rectifier...that is a 2 pronged doohickey screwed to the frame below the tank... cant find anything else that it could be... acutall it appears as its a reg/rec in one unit... i have just ordered a new one so see what happens there...thanks again OG
