Posted April 20, 201114 yr Firstly can i ask does the seat lift via the helmet lock doodah under the left hand side of the seat and 2 pivot hinges or is it a bolt on?. Mine is a 78 registered model by the way and secondly the left hand switchgear on mine is off an RXS and is causing a straight short when operated.. If there are any RS125 owners could you take a pic if the left hand switch gear please so i can see which one i need, Thanks in advance Mick
April 23, 201114 yr Firstly can i ask does the seat lift via the helmet lock doodah under the left hand side of the seat and 2 pivot hinges or is it a bolt on?. Mine is a 78 registered model by the way and secondly the left hand switchgear on mine is off an RXS and is causing a straight short when operated.. If there are any RS125 owners could you take a pic if the left hand switch gear please so i can see which one i need, Thanks in advance Mick Mick Mine (1981,125dx,2A0 model) has two bolts underneath at the back of the seat that need to be undone as well as the helmet lock then it slides out backwards not sideways. Hope this helps Pete
