Evening all
Im Dave, Ive just started a lil project on a DT 125 lc 89, fully restored bar the engine were i am having a world of trouble. I have in total 3 bottom ends and componets, but still out of all of this the one thing that is wrong with all of them is the gear selector spring is week.
So here it is.
I am after a complete gear selector shaft and end.
Throttle twist grip and cable
HT lead
some good condition two finger handle bar leavers.
Possible parts required to convert Dt125 to a Dt 175.
Many thanks dave
welcome
tar thank for info is there any were u can get a wiring diagram for these bikes and possible ht leads?
Haynes workshop manuals have wiring diagrams, as for HT leads they are an integral part of the ignition coil and are not supposed to be taken out and changed although it has been done before. More commonly if the internal thread is stripped at the plug cap end you may be able to cut off 20mm of the length and screw back into fresh lead?
