NewBEEEE
This post is 4967 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Evening all
Im Dave, Ive just started a lil project on a DT 125 lc 89, fully restored bar the engine were i am having a world of trouble. I have in total 3 bottom ends and componets, but still out of all of this the one thing that is wrong with all of them is the gear selector spring is week.
So here it is.
I am after a complete gear selector shaft and end.
Throttle twist grip and cable
HT lead
some good condition two finger handle bar leavers.
Possible parts required to convert Dt125 to a Dt 175.
Many thanks dave
Link to comment
Share on other sites
Haynes workshop manuals have wiring diagrams, as for HT leads they are an integral part of the ignition coil and are not supposed to be taken out and changed although it has been done before. More commonly if the internal thread is stripped at the plug cap end you may be able to cut off 20mm of the length and screw back into fresh lead?
Link to comment
  • Recently Browsing
