SRX / Radian ? Will they mate ?
I am trying to find out if a Radian (86) top triple
tree or the upper & lower as a unit will bolt up to
an 86 SRX. If so will it retain same spacing for my front
wheel? As you can probably figure out I want to install
a standard handle bar and I don't want to drill holes in my
stock triple tree to mount risers. Radian triple trees are
available on ebay right now at reasonable prices. Unless
someone on here has a Radian top triple they want to sell.
Thanks,
Well I got you to look :) I figure I will need a lot
of views to get an answer to my question .
Well I bought an entire triple tree assembly with risers
off ebay for $40 bucks . So will see . :rolleyes:
share your findings, that way, we can answer your question :lol:
Not really , The fork diameter and spacing is right . The center stem is off so
Radian top triple will not fit on SRX stem . The SRX stem is about an inch longer
and completely different on top so I can't swap stems so the only option is to
cut and lengthen Radian stem to fit SRX . I may try this since I work in a machine shop
but I'm going to look into other options also. For now I'm putting it back together and
enjoying the summer .
