April 13, 201114 yr I am trying to find out if a Radian (86) top triple tree or the upper & lower as a unit will bolt up to an 86 SRX. If so will it retain same spacing for my front wheel? As you can probably figure out I want to install a standard handle bar and I don't want to drill holes in my stock triple tree to mount risers. Radian triple trees are available on ebay right now at reasonable prices. Unless someone on here has a Radian top triple they want to sell. Thanks,
April 14, 201114 yr Author Well I got you to look I figure I will need a lot of views to get an answer to my question .
April 17, 201114 yr Author Well I bought an entire triple tree assembly with risers off ebay for $40 bucks . So will see .
April 24, 201114 yr Author share your findings, that way, we can answer your question Not really , The fork diameter and spacing is right . The center stem is off so Radian top triple will not fit on SRX stem . The SRX stem is about an inch longer and completely different on top so I can't swap stems so the only option is to cut and lengthen Radian stem to fit SRX . I may try this since I work in a machine shop but I'm going to look into other options also. For now I'm putting it back together and enjoying the summer .
