Greetings, I have a 1982 XJ 750 Maxim. Looking to install forward controls. Need to take out the front bottom motor mount bolts. According to the manual, the bolts come out easily after removing the nut. The left side slid right out. The right will not come out and there appears to be a gear of some sort inside. Has anyone ever faced this before? How do I get the bolt out and now the I have followed some "Expert" advice, I cut the bolt, I have to replace the bolt with gear. Looks like I can jaek the engine up in the frame enough to make the switch but looks like I need a new bolt/gear and seal. The gear appeares to be very lose and not attached to a chain of any kind. Any help out there? Thanks you very much.
