dt175e frame question
i am wondering what the size of the mounting hole for the rear flashers is
mine are missing and i need to know the size so i can build new brackets
They are 8mm mountings. The brackets were often removed for some reason, are you welding some back on?
, they had a turned edge to give them strength and rigidity
Cos when you lob the bike off road the indicators get bust, when you get on with MX boots guess what, yep the indicators get bust. When your on the trail and the mud and stones are flying, yep the bloody things get bust.
Add to that they rust out and the indicators sieze into them too, so they get cut off.
Addmitedly my brackets got the cruelest cut thanks to a smarmy MOT man long after the indicators were consigned to the bin, "if the provision is there they should be fitted and work, thats failed".
Hour later i was back minus the provision :lol: He didn't like it but he had to pass it.
i am not going off road with this bike
i am using it for general transportaion
yes i am going to fabricate new ones and
weld them back on so i can be street legal again
i think mine were removed to fit on after market fender
the rouned edge probably got in the way
i wish they were like the mounts for the front foot peg
that spring back in place
i go to pasadena city college for welding
just flush cut and redrill hole
or weld hole sheut then redril
