March 31, 201114 yr i am wondering what the size of the mounting hole for the rear flashers is mine are missing and i need to know the size so i can build new brackets
April 1, 201114 yr Moderator i am wondering what the size of the mounting hole for the rear flashers is mine are missing and i need to know the size so i can build new brackets They are 8mm mountings. The brackets were often removed for some reason, are you welding some back on? , they had a turned edge to give them strength and rigidity
April 1, 201114 yr Moderator They are 8mm mountings. The brackets were often removed for some reason, are you welding some back on? , they had a turned edge to give them strength and rigidity Cos when you lob the bike off road the indicators get bust, when you get on with MX boots guess what, yep the indicators get bust. When your on the trail and the mud and stones are flying, yep the bloody things get bust. Add to that they rust out and the indicators sieze into them too, so they get cut off. Addmitedly my brackets got the cruelest cut thanks to a smarmy MOT man long after the indicators were consigned to the bin, "if the provision is there they should be fitted and work, thats failed". Hour later i was back minus the provision He didn't like it but he had to pass it.
April 2, 201114 yr Author i am not going off road with this bike i am using it for general transportaion yes i am going to fabricate new ones and weld them back on so i can be street legal again i think mine were removed to fit on after market fender the rouned edge probably got in the way i wish they were like the mounts for the front foot peg that spring back in place i go to pasadena city college for welding
April 2, 201114 yr Author i am not going off road with this bike i am using it for general transportaion yes i am going to fabricate new ones and weld them back on so i can be street legal again i think mine were removed to fit on after market fender the rouned edge probably got in the way i wish they were like the mounts for the front foot peg that spring back in place i go to pasadena city college for welding just flush cut and redrill hole or weld hole sheut then redril
April 2, 201114 yr Moderator just flush cut and redrill hole or weld hole sheut then redril ???? What are you saying ?
