Re-jetting plan, what do you all think.
johnsnownw
This post is 4980 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
So, I finally decided to add Uni-Pod filters and re-jet. I'm using these filters:
Now the plan is to re-jet going 2 up on main, 2 washers to raise the needle, and 1 up on the pilot. Anyone think this isn't the way to go? I've been debating on going 2 up on the pilot as well, but I think that might be too much.
I've decided to start out as 2 up on the Main as that's what they suggest doing with BS34 carbs on the 650's, here: http://www.amckayltd.com/carbguide.pdf
Let me know what you all think.
id do your pilot jet 1st as thats the most important, then start it up and do some checks, then the needle, (start up and check again) then the main if its running lean on top.
Pod filters with a capped off end can cause air flow problems (well on 2 stroke motors they do) there maybe a air corrector kit available which will save you a lot of trouble.
Thanks for the suggestions all!
Preload, I hadn't heard that...I'll make sure to watch for it.
You get the same effect as the pressure wave that returns in the expansion chamber and keeps the charge in the cylinder, same thing happens in the filter, trouble is the metal top causes the wave to comeback at the wrong time and restrict the incoming air.
If you must have pods you want to try and get full foam jobbies.
or put them on the end of a tube to minimise the effect.
the main problem I think is you have CV carbs, it upsets the diaphram movement (prob the pressure wave you mentioned)
So, is this one of those, it CAN happen, or it WILL happen deals?
Hey John
I like the red Uni's...if they don't work use them as targets for the 357 or send them to me and I'll see if they work on the 44 mag :lol: .
Rocky
I have told this story several times now.
Tuning shop in Towcester near me called TTS (used by many national magazines and people like Jack Frost etc)I expected pods of some sort when i had quite an aggressive tune done, they will fit pods for 2 reasons only.
Tuning for the drag strip, or a direct customer request.
Unless your running all or mostly WOT they do not have enough benefits over a good filter in a regular airbox to be worthwhile.
Of course, asthetics is entirely different
Where were you when I was buying these filters? It's very inconsiderate of you, Cynic. ;)
I decided to go pods because I wanted increased air flow so I could up the jets. My 400 has always seemed to run lean unless I turn the mixture screws way way out. Also, I'm tired of dealing with the stock set up when I want to do anything with the carbs...it's just a pain. I guess the second reason is that I'm lazy.
Hey John
I like the red Uni's...if they don't work use them as targets for the 357 or send them to me and I'll see if they work on the 44 mag .
Rocky
If I were going to destroy them, I think I'd do it myself. Then again, I wouldn't mind seeing what a 44 mag would do to them...hmmm
Are you sure that turning the screw out richens the mixture but I thought turning the screw in richened the mix? I havnt worked on a XS400 for over 20+ years so don't take this as gospel. Also the air screw only effects the first 20-25% of rev range so doesnt effect much above that.
Yup!
Alright, well here's how the re-jetting went. I went one up on the main, and left everything else as-is, and the bike runs pretty well. The only issue I have is that every once in a while it will backfire through the carbs. Not really enough to be a concern, but I had to turn the mixture screws out about 5.5 turns. I did try to go one up on the pilot, but it was running like crap. If I'm not mistaken backfiring through the carbs mean the mixture is just a tad lean. Does anyone think going 1 down on the air jet would help?
Actually, I'm a little confused about the starter jet and air jet after looking at my Haynes manual.
Thanks again guys.
