Posted March 31, 201113 yr So, I finally decided to add Uni-Pod filters and re-jet. I'm using these filters: Now the plan is to re-jet going 2 up on main, 2 washers to raise the needle, and 1 up on the pilot. Anyone think this isn't the way to go? I've been debating on going 2 up on the pilot as well, but I think that might be too much. I've decided to start out as 2 up on the Main as that's what they suggest doing with BS34 carbs on the 650's, here: http://www.amckayltd.com/carbguide.pdf Let me know what you all think.
March 31, 201113 yr Moderator Anybodys guess, carburation it's a bloody nightmare when you start messing with it
April 1, 201113 yr id do your pilot jet 1st as thats the most important, then start it up and do some checks, then the needle, (start up and check again) then the main if its running lean on top.
April 1, 201113 yr Pod filters with a capped off end can cause air flow problems (well on 2 stroke motors they do) there maybe a air corrector kit available which will save you a lot of trouble.
April 1, 201113 yr Author Thanks for the suggestions all! Preload, I hadn't heard that...I'll make sure to watch for it.
April 1, 201113 yr Moderator Thanks for the suggestions all! Preload, I hadn't heard that...I'll make sure to watch for it. You get the same effect as the pressure wave that returns in the expansion chamber and keeps the charge in the cylinder, same thing happens in the filter, trouble is the metal top causes the wave to comeback at the wrong time and restrict the incoming air. If you must have pods you want to try and get full foam jobbies.
April 1, 201113 yr Moderator You get the same effect as the pressure wave that returns in the expansion chamber and keeps the charge in the cylinder, same thing happens in the filter, trouble is the metal top causes the wave to comeback at the wrong time and restrict the incoming air. If you must have pods you want to try and get full foam jobbies. or put them on the end of a tube to minimise the effect. the main problem I think is you have CV carbs, it upsets the diaphram movement (prob the pressure wave you mentioned)
April 1, 201113 yr Author You get the same effect as the pressure wave that returns in the expansion chamber and keeps the charge in the cylinder, same thing happens in the filter, trouble is the metal top causes the wave to comeback at the wrong time and restrict the incoming air. If you must have pods you want to try and get full foam jobbies. So, is this one of those, it CAN happen, or it WILL happen deals?
April 1, 201113 yr Author Well, I decided to order these due to the end cap issue: I guess I'll probably send the others back, they aren't exactly cheap.
April 2, 201113 yr Hey John I like the red Uni's...if they don't work use them as targets for the 357 or send them to me and I'll see if they work on the 44 mag . Rocky
April 2, 201113 yr Moderator So, is this one of those, it CAN happen, or it WILL happen deals? I have told this story several times now. Tuning shop in Towcester near me called TTS (used by many national magazines and people like Jack Frost etc)I expected pods of some sort when i had quite an aggressive tune done, they will fit pods for 2 reasons only. Tuning for the drag strip, or a direct customer request. Unless your running all or mostly WOT they do not have enough benefits over a good filter in a regular airbox to be worthwhile. Of course, asthetics is entirely different
April 2, 201113 yr Author I have told this story several times now. Tuning shop in Towcester near me called TTS (used by many national magazines and people like Jack Frost etc)I expected pods of some sort when i had quite an aggressive tune done, they will fit pods for 2 reasons only. Tuning for the drag strip, or a direct customer request. Unless your running all or mostly WOT they do not have enough benefits over a good filter in a regular airbox to be worthwhile. Of course, asthetics is entirely different Where were you when I was buying these filters? It's very inconsiderate of you, Cynic. I decided to go pods because I wanted increased air flow so I could up the jets. My 400 has always seemed to run lean unless I turn the mixture screws way way out. Also, I'm tired of dealing with the stock set up when I want to do anything with the carbs...it's just a pain. I guess the second reason is that I'm lazy. Hey John I like the red Uni's...if they don't work use them as targets for the 357 or send them to me and I'll see if they work on the 44 mag . Rocky If I were going to destroy them, I think I'd do it myself. Then again, I wouldn't mind seeing what a 44 mag would do to them...hmmm
April 2, 201113 yr My 400 has always seemed to run lean unless I turn the mixture screws way way out. Are you sure that turning the screw out richens the mixture but I thought turning the screw in richened the mix? I havnt worked on a XS400 for over 20+ years so don't take this as gospel. Also the air screw only effects the first 20-25% of rev range so doesnt effect much above that.
April 3, 201113 yr Author Are you sure that turning the screw out richens the mixture but I thought turning the screw in richened the mix? I havnt worked on a XS400 for over 20+ years so don't take this as gospel. Also the air screw only effects the first 20-25% of rev range so doesnt effect much above that. Yup!
April 8, 201113 yr Author Alright, well here's how the re-jetting went. I went one up on the main, and left everything else as-is, and the bike runs pretty well. The only issue I have is that every once in a while it will backfire through the carbs. Not really enough to be a concern, but I had to turn the mixture screws out about 5.5 turns. I did try to go one up on the pilot, but it was running like crap. If I'm not mistaken backfiring through the carbs mean the mixture is just a tad lean. Does anyone think going 1 down on the air jet would help? Actually, I'm a little confused about the starter jet and air jet after looking at my Haynes manual. Thanks again guys.
