March 30, 201114 yr Hello from Sunny New Zealand. I have a 1992 DT 50. Got the bike with wiring stuffed up. I have managed to get all the wiring connected. So all the lights and indicator work now. But if I have the head light on and use the indicators all the light go dim and brit. Please can you give me some pointer as to what the issues could be? Thank you. Hectic.
March 30, 201114 yr Moderator Dirty or tarnished connectors. Old loom (oxidised) dirty earth connections. Lots of cleaning and investigation needed
March 30, 201114 yr Author Dirty or tarnished connectors. Old loom (oxidised) dirty earth connections. Lots of cleaning and investigation needed Thanks, will start replacing all the connectors and clean up the harness where I can. Thank you.
March 31, 201114 yr Author Thank you for the hint. cleaned up earth wiring and indicators are working very well. Thank
