hey whats up im having some problems with my 79 mx175. at first i couldnt get any spark so i replaced the cdi and fixed that problem but now i cant get it to rev up past about half throttle. it will sit and idle with no problem. I was told it might be getting to much air but i dont see how. ive cleaned the carb and replaced the spark plug any help on this issue would much appreciated thanks
Has it ever run properly in your care?
Are you sure you swapped like for like CDi's as there is only one wire difference.
When you say it won'nt rev do you mean riding down the road or static?
there are 6 and 7 wire cdi units which aren't interchangeable. I have a list at home of what cdi will work
well im pretty sure the cdi i put is the wrong one i have a 7 wire on there and it needs a six it is there any way to make it work?
well im pretty sure the cdi i put is the wrong one i have a 7 wire on there and it needs a six it is there any way to make it work? would a cdi off of a yt175 work?
I would have thought a 79 bike needed a seven wire CDI. the clue is, is there a red wire from the magneto? if so its a 7 wire. well it is on uk bikes but not 100% sure on US models
theres not a red wire from the mag just white/red, black, and brown if i combo the brown and red and ground the brown at the same time with the throttle held wide open it revs up perfect but if i let of off the tthrottle it kills the bike
yes then you need a 6 wire CDI so long as the stator only has ( ignoring lighting) 2 coils.
it only has the one source coil and a pulser this bike doesn't have lights.
if you know the part number of the correct CDI enter it into the 'boats.net' search box. if youre lucky it will say if it is common to others
ok thanks for the help
