March 26, 201115 yr hello folks i recently bought a 06 yamaha ybr 125 from a family member. the bike wont start and i have noticed the heater plug going into carburettor has been damaged.would the heater plug prevent the bike from starting because ive been told by garages it should not stop it starting up and been told by other garages it should not stop it starting up. plz hlp lol.im a newbie to bikes
March 28, 201115 yr hello folks i recently bought a 06 yamaha ybr 125 from a family member. the bike wont start and i have noticed the heater plug going into carburettor has been damaged.would the heater plug prevent the bike from starting because ive been told by garages it should not stop it starting up and been told by other garages it should not stop it starting up. plz hlp lol.im a newbie to bikes Hi, There are few things I would check before start playing with the carb. My suggestion - begin with engine cranking check. You can remove the spark plug and use the kick starter to see if the piston is moving. At the same time you can check the spark as well (attach the spark plug to the cable and keep the sparkplug in contact with the engine body while cranking the engine).Check the oil. Next thing is the fuel. Old fuel can cause start problems. You can drain the old petrol and put some fresh fuel.That's in case the bike has not been used last few months. Air filter cleaning and oil change are good thing to do as well, bu they should not be preventing engine start.
March 30, 201115 yr Author Hi, There are few things I would check before start playing with the carb. My suggestion - begin with engine cranking check. You can remove the spark plug and use the kick starter to see if the piston is moving. At the same time you can check the spark as well (attach the spark plug to the cable and keep the sparkplug in contact with the engine body while cranking the engine).Check the oil. Next thing is the fuel. Old fuel can cause start problems. You can drain the old petrol and put some fresh fuel.That's in case the bike has not been used last few months. Air filter cleaning and oil change are good thing to do as well, bu they should not be preventing engine start. the engine does crank over it just wont start.ive been told by yamaha dealership if the heater plug is damaged theres a good chance the bike wont start up.had to order new part waiting on it coming into dealership £32 nearly fainted at the price for such a small part lol
April 14, 201115 yr Author the engine does crank over it just wont start.ive been told by yamaha dealership if the heater plug is damaged theres a good chance the bike wont start up.had to order new part waiting on it coming into dealership £32 nearly fainted at the price for such a small part lol happy days!! we finally found the fault. there was petrol sitting at bottom of carburettor that didnt smell very strong( think it turned it sour after all it had been sitting doing nothing for 2 yrs in a garage) so we cleaned the jet and also cleaned the needle as well put it all back together bike started first time
