Sorry to swamp the forum with loads of messages.
My bike didnt have a battery so i bought a new one, however im not sure how or what to connect to it!
I have the red wire + fuse and black but i think there needs to be another wire connected to it.
I got a pic of a bike on ebay with the battery wired up, im assuming mine should look something like it.
  • 3 weeks later...
Red to pos(+), black to neg(-).
...i hope so! :D:D
I was jus wondering if there are any other wires that would go to the battery?
like a thicker positive? as shown on the dtr in the pic :?:
not nessicerily mate, depeneds how much power is going to be drawn from the battery, probobly not to much in a dt125 case. the 2 loose wires i can see in the second picuture are about as thick as those on my dt50cc. so there shouldnt be any proboblem there, the other dt may have a electric start or something...
thanks skyline.
I just got my battery filled up at a local motor shop, do i need to charge it now, or can i jus whack it in?
Whack it in
cool, i'll whack it in tomorrow morning!
thanks
Whackin' it in should be OK......as long as the shop where you bought it, filled it with fresh acid. Then your charging system on your bike should be adequate to do the rest. :wink:
cool, i'll let u know after its been whacked in! hopefully it will charge, the shop is quite reliable
There is normally only 1 red wire from the +ve and 1 black from the -ve on the DTR battery.
That picture may be from the old electric start model (DTR125E). Thay have a second thicker wire for the feed to the starter. Either that or the owner has added a second +ve feed into the loom for some reason.
After the battery got whacked in everything came together!
dash lights, indicators and relay!
i'm very happy!
:D:D:D:D:D:D:D
thanks everyone
  • 3 months later...
please could you confirm your bike is a mk3 dt125lc? i have got a similar bike with a rear dist brake, i thought it was a dt125lc but been told on the forum it was a dtr as dt125lc has drum brakes. your pics are helpful. would it be poss for you to send me a full pic for comparisan. [email protected]
cheers
cheers
Have a look here
http://www.yamahaclub.com/forums/index.php...pic=1526&st=100
..its about a 3rd down the page.
im pretty confident its a DTR
