November 13, 200421 yr Sorry to swamp the forum with loads of messages. My bike didnt have a battery so i bought a new one, however im not sure how or what to connect to it! I have the red wire + fuse and black but i think there needs to be another wire connected to it. I got a pic of a bike on ebay with the battery wired up, im assuming mine should look something like it.
December 4, 200421 yr Author ...i hope so! I was jus wondering if there are any other wires that would go to the battery? like a thicker positive? as shown on the dtr in the pic :?:
December 4, 200421 yr not nessicerily mate, depeneds how much power is going to be drawn from the battery, probobly not to much in a dt125 case. the 2 loose wires i can see in the second picuture are about as thick as those on my dt50cc. so there shouldnt be any proboblem there, the other dt may have a electric start or something...
December 4, 200421 yr Author thanks skyline. I just got my battery filled up at a local motor shop, do i need to charge it now, or can i jus whack it in?
December 5, 200421 yr Moderator Whackin' it in should be OK......as long as the shop where you bought it, filled it with fresh acid. Then your charging system on your bike should be adequate to do the rest. :wink:
December 5, 200421 yr Author cool, i'll let u know after its been whacked in! hopefully it will charge, the shop is quite reliable
December 5, 200421 yr There is normally only 1 red wire from the +ve and 1 black from the -ve on the DTR battery. That picture may be from the old electric start model (DTR125E). Thay have a second thicker wire for the feed to the starter. Either that or the owner has added a second +ve feed into the loom for some reason.
December 6, 200421 yr Author After the battery got whacked in everything came together! dash lights, indicators and relay! i'm very happy! thanks everyone
April 4, 200520 yr Sorry to swamp the forum with loads of messages. My bike didnt have a battery so i bought a new one, however im not sure how or what to connect to it! I have the red wire + fuse and black but i think there needs to be another wire connected to it. I got a pic of a bike on ebay with the battery wired up, im assuming mine should look something like it. please could you confirm your bike is a mk3 dt125lc? i have got a similar bike with a rear dist brake, i thought it was a dt125lc but been told on the forum it was a dtr as dt125lc has drum brakes. your pics are helpful. would it be poss for you to send me a full pic for comparisan. [email protected] cheers
April 5, 200520 yr Author please could you confirm your bike is a mk3 dt125lc? i have got a similar bike with a rear dist brake, i thought it was a dt125lc but been told on the forum it was a dtr as dt125lc has drum brakes. your pics are helpful. would it be poss for you to send me a full pic for comparisan. [email protected] cheers Have a look here http://www.yamahaclub.com/forums/index.php...pic=1526&st=100 ..its about a 3rd down the page.
April 5, 200520 yr Have a look here http://www.yamahaclub.com/forums/index.php...pic=1526&st=100 ..its about a 3rd down the page. Very, very early DT125R's had a drum brake on the rear. Model was 3DB1. Different carb too. Rare but they are still around.
