XVS 125 is it possible?
Teague
This post is 4997 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Yes, but why would you want to?
Are you adding different end-cans?
yes but...(lol)
you will mess up the air/fuel ratio and the xvs engine is an absolute pig to get spot on!
if you take them off then ur gonna have to fiddle with the carb....and im tellin you now m8 its a ball ache! just write down what you have changed and by how much then if somethin dont work you can put it back to the point where it did work :D
This is an 'easy mod' to do, chop them out with a grinder and joiners claw hammer etc, experience the louder noise and much slower speeds B)
is it possible to remove the end mufflers from the downpipes on the xvs 125?
Clarify. Do you want to remove the concave dish at the outlet, or the muffler that shrouds the exhaust.
if its noise that you want, some folks have just drilled holes in the dishes. That way its possible to plug them back up if its not the desired effect, or as Paul says, performance negative impact
i should of said that....has more impact :lol::lol::lol:
