Just bought a used 07 VStar with 5k miles. After about 100 miles the speedometer stopped working. The rest of the gauges/odometer/lights all work. The manual says when you turn the key to "On" the bike does an electric check and the speedometer fans from 0 to the far right and then returns to 0. Mine no longer does this. I have checked the fuses and they all appear fine. Anyone else have this problem? Any suggestions?
Does the needle move at all when you drive? Does the bike start? I've heard of cases where the speedo sticks due to warping of the speedo dial. But before you panic check your battery connections are tight... If you bought it from a dealer I'd take it back and ask them to fix it as it developed a fault within 100 miles of purchase.
