Posted March 21, 201114 yr Hi , trying to get my 1986 TT 600 road legal , head and tail lights do work but need to fit indicators and brake lights to get licienced . Is it possible to do this with existing system or do I have to fit a complete wiring loom , stator/ rotar etc from an xt to do the job ? Any help or suggestions would be appreciated , Cheers
March 21, 201114 yr The wiring should be already there for brake light and indicators. Have a look at the loom near the kickstart area and see if you can see a Green/Yellow and Brown wire which will be for the stop light switch and look at the front and rear of the loom and see if you can see a Dark green and Dark Brown wires which will be the feed for the Left and Right indicators which then go to Earth/Black wire .Tony
March 21, 201114 yr Author The wiring should be already there for brake light and indicators. Have a look at the loom near the kickstart area and see if you can see a Green/Yellow and Brown wire which will be for the stop light switch and look at the front and rear of the loom and see if you can see a Dark green and Dark Brown wires which will be the feed for the Left and Right indicators which then go to Earth/Black wire .Tony Cheers Tony, will check it out.
March 22, 201114 yr Hi Finster If its the early 55U model there should be indicator wires within the harness, you will need a battery as well which should be located in a small holder behind the LHS side panel. TTB
March 22, 201114 yr Author Hi Finster If its the early 55U model there should be indicator wires within the harness, you will need a battery as well which should be located in a small holder behind the LHS side panel. TTB Hey TTB, thanks for the imput , its the 59 X model ,
March 23, 201114 yr Hey TTB, thanks for the imput , its the 59 X model , Yes couse it is, where did i get 55U , sound like a german sub. Anyway yes there should be green and brown wires rnning through the harness, switch gear is the same as the XT600 i think. Indicators for the TT are hard to come by in the UK, not too bad in the states. Front brake light will have to be a hydraulic unit piped into the brake reservoir.you could find an XT600 harness and alter that or get a manual and make one. TTB
March 23, 201114 yr Author Yes couse it is, where did i get 55U , sound like a german sub. Anyway yes there should be green and brown wires rnning through the harness, switch gear is the same as the XT600 i think. Indicators for the TT are hard to come by in the UK, not too bad in the states. Front brake light will have to be a hydraulic unit piped into the brake reservoir.you could find an XT600 harness and alter that or get a manual and make one. TTB Thanks TTB , I appreciate the help , Cheers
