March 12, 201114 yr Ok here goes.. I start it up (first start of the day)using the choke, alot of popping noise like 1 plug is not hitting. I replaced the plugs but getting the same noise. So I am thinking could it be the carbs. Also when I am on the freeway cruising about 70 it is like I am squeezing the clutch in and out. Any idea's.... egarrett
March 31, 201114 yr Author Well decided to break down the carbs and replace the plug wires and didn't know that the wires had a solenoid on them for each wire so that may be a factor also. So anyway disregard the previous thread.
