March 4, 201115 yr my kickstart wont go all the way over,i sprayed some seafoam into the cylinders and its kinda starting to budge a little bit but i dont wanna force it and cause more problems of a piston is seized. advice? or should i just get a new bike....thanks!
March 4, 201115 yr sounds like it's seized to me, keep using the sea foam or ACF50 and keep using the kick start little by little , once it is unseized if you get that far does not mean your troubles are over
March 4, 201115 yr Moderator Whats seafoam? I would use diesel oil pour some into each cylinder and leave overnight.
March 5, 201115 yr Author yeah i can feel it starting to turn. im just trying not to force it cos i wanna avoid doing more damage. thanks guys!
