November 5, 200421 yr Anyone any experience of thunderace clutch slip and is it expensive to replace? Oddly enough it is worse when cold.
November 5, 200421 yr Moderator Interesting how it slips when it's cold? If you're handy with the spanners, replacing the clutch is a piece of cake 8) ...although I'm really not sure how much one will run on your side of the pond. :wink:
October 19, 200718 yr Anyone any experience of thunderace clutch slip and is it expensive to replace? Oddly enough it is worse when cold. before you get the tool box out and give your self a head frying make sure that you have the correct grade of oil if its motor bike oil you wont have a problem though if its normal car engine oil you will get clutch slip try changing the oil and put on a new oil filter you will get all you need from halfords i sugest an engine flush before you change oil this should cure your problem failing that mate then its the clutch hope that helps
