Anyone any experience of thunderace clutch slip and is it expensive to replace?
Oddly enough it is worse when cold.
If you're handy with the spanners, replacing the clutch is a piece of cake 8) ...although I'm really not sure how much one will run on your side of the pond. :wink:
  • 2 years later...
before you get the tool box out and give your self a head frying make sure that you have the correct grade of oil if its motor bike oil you wont have a problem though if its normal car engine oil you will get clutch slip try changing the oil and put on a new oil filter you will get all you need from halfords i sugest an engine flush before you change oil this should cure your problem failing that mate then its the clutch hope that helps :lol:
