I just started restoring a 1983 IT250K and have a couplke questions, I'm hoping someone can help me with.
1) Does anyone know the torque spec for the head bolts?
2) Does anyone know of an epoxy or something I can use to fix the plastic gas tank? It has a small crack.
Any help would be appreciated, Thank you!
Now then Solo-rider,,,, post up an intro" . or you"l be riding solo this summer .:D
Dt250 torque settings head bolts = 10mm bolts 25-30lbs /ft [4.2 -4.5kg/m]
8mm bolts 15-18 lbs/ ft. [2.0 kg-2.5kg]
plenty plastic patch for tanks on E,bay.
